How can I remove the "GMT" information from a date field?
LLawton
I have a computed date field (date only, not timestamp) that uses the function firstTimeEntryDate() to find the earliest time entry on an item.
The output looks like this: Jan 13, 2014 GMT+00:00
I want to get rid of the useless "GMT" information.
My first instinct is to try to parse the date and reformat it, so I end up with something that looks like this:
timestamp(
concat(
Substring( MonthOfYearName( firstTimeEntryDate() ) , 1 , 3 ) ,
Text( " " ) , ToText( getDay( firstTimeEntryDate() ) ) ,
Text( ", " ) , ToText( getYear( firstTimeEntryDate() ) )
This doesn't work because "The Timestamp() function takes a single argument which must be a string in the format java.text.SimpleDateFormat".
I know I can do the parsing into a text field, but I want a date.
Does anybody have a solution to format a computed date field, or more specifically remove the GMT information?
KaelLizak
(To:LLawton)
Hello Laurent,
This issue is covered by RFC 107695. Please open a case with PTC Integrity Support to add your organization to it.
Warm Regards,
Kael
(Edited 2015-02-18EST10:48 by Kael: Mis-typed RFC number as 107696 instead of 107695)
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
4 REPLIES 4
KaelLizak
(To:LLawton)
Hello Laurent,
Warm Regards,
Kael
Kind Regards,
Kael Lizak
khoppe
(To:KaelLizak)
Hello Kael,
I like to have a look into the SPR.  Does also exist an SPR no. for it?
Klaus
KaelLizak
(To:khoppe)
Hello Klaus Hoppe‌,
Because that RFC was a feature request rather than a defect report, it does not exist as an SPR.  I searched the existing Ideas, and found there is an Idea which might be interpreted as being close:  Override locale information on date fieldsYou probably want to create your own Idea to reflect RFC 107695/CS85012.
Kind Regards,
Kael
Kind Regards,
Kael Lizak
LLawton
(To:KaelLizak)
I don't understand why this question is marked as solved; I'm the author and I didn't do that.
Especially since the solution is that there is no solution, just an idea that is marked as "might be considered in the future".
