In the Sandbox, I am working on a file which is checked-out.
The work will continue for few weeks on the file.
At the end of the work I want to check-in the file.
But during the phase I am working with the file, I want to synchronize the recent contents from Sandbox area to Server Repository in case my PC hard-disk crashes.
I will not loose the contents under that circumstance.
Remember I don't want to create another version of the element by checking-in every day before leaving the office.
Is there any mechanism to Synchronize either an element or the Sandbox contents to the Server repository, so that I always have another copy?
In CM/Synergy, there is a similar feature. That's why I am asking that it might be possible in PTC also as they are both SCM tool.
Thank you.
Regards
It is not currently possible to synchronize a file to the server without check in.
One option would be to use a branch to check in work, then merge to the trunk revision when you are done. Another option would be to have a sandbox on a network location, so you would not lose data if your PC crashes.
