How to add Relationships between 2 document contents with CLI ? Example:
Chittaranjan_11
Hello Team,
Example:
Input Document (Input ID 123)
Requirement Document (Requirement ID 456)
Input Decomposed To Requirement OR vice-versa
How to make this relationship via CLI command ?
Thanks in advance.
1 ACCEPTED SOLUTION
I got the solution with addrelationship command,
Example: Input 123 --> Decomposed To --> Requirement 456
im editissue --hostname=XXXX --port=XXXX --user=XXXX --password=XXXX --addRelationships="Decomposed To:456" 123
Its working!!
Thanks @MichaelChatel
2 REPLIES 2
Do you wish to set relationships at the time of creation, or you're trying to link these together, after the fact?
You may want to open a Support case for this, but I imagine you'd want to use the addRelationships and removeRelationships options, if trying to do this after the fact?
ex.
https://support.ptc.com/help/windchillrvs/r12.3.1.0/en/#page/IntegrityHelp%2Fim_editissue.html%23
Its working!!
