After modifying the Viewset in Staging Server, the Field ID will be different when reflected to the Production Server. So it's cumbersome every time it need to modify Viewset.
Since you are importing and using Viewset in Production Server, you need to develop the Viewset in Production Server and then publish it directly to Production Server.
