The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
How to see the exact Label (size, numbers of labels etc.) at a checkpoint via CLI
JensN.
Hi @all,
an example: we have a checkpoint 1.2 with label "Test1". Another user adds another label "Test2,Test3" to this checkpoint. If i want to look via commandline with
si viewprojecthistory -P#<projectpath> --rfilter=labeled --fields=labels/<projectpath>
than i get this output:
Test1,Test2,Test3
So i couldnt see if this is one label, or two lables, or three labels. Is there any way to see that there were originally two labels?
Thanks, and kind regards, Jens
6 REPLIES 6
Jens,
Which version of Integrity are you using? When I test this in 10.2, the labels are seperated by a new line. They appear like this:
Test1
Test2,Test3
I also used slightly different syntax in my command. I used this instead of what you posted:
Maybe give that a try and see if you get different results.
JensN.
(To:jgorsline)
Hi Jeremy,
we're also using 10.2 (with HF1). And unfortunately also with your syntax i got all labels in one line. So here is my commandline without placeholders:
si viewprojecthistory --P#/Spielwiese#Test --rfilter=labeled --fields=labels
and also with this line:
si viewprojecthistory --project=/Spielwiese/Test/project.pj --rfilter=labeled --fields=labels
i got this output:
Test1,Test2,Test3,Test4,Test5
This is Checkpoint 1.6 in this project, and it has three labels: the first label was set with the checkpoint: "Test1,Test2,Test3", second Label added later: "Test4", and a third label added even later: "Test5". Here a screenshot from the projecthistory within the client:
Is there any flag maybe in the preferences which can handle this?
kind regards, Jens
That information clarifies it a bit. The command lists the labels with each new checkpoint starting a new line. If you have multiple labels on one checkpoint, they will show up on the same line.
JensN.
(To:jgorsline)
Hi Jeremy,
thanks for your answer. So it seems to go the usual way: we have to open a RfC for this...
kind regards, Jens
mrump
(To:JensN.)
Hi Jens,
in 10.2 there is an option "--xmlapi" that gives you more detailed information.
will result in :
HTH Matthias
Note: the --xmlapi option is available for many CLI command but unfortunately not for all.
JensN.
(To:mrump)
Hi Matthias,
thanks, this is very helpful!
kind regards, Jens
