Howto Rename Subproject from lower to upper case
kschaefer-2
2-Guest
by mistake a subproject has been created with a lower case letter "myproject" instead of upper case letter ("Myproject") in the beginning.
So I tried to rename it using the SI-Function "Subproject move" but I get an error message that the project already exists.
Is there any way to do this kind of rename?
Best regards,
Kai
1 ACCEPTED SOLUTION
AlanLew
(To:kschaefer-2)
Unfortunately, if the Move Subproject command didn't rename the project then there is no current way to accomplish this without using advanced techniques. There is an RFC posted to the R&D team to resolve this lack of functionality, RFC 109145.
Please open a new Case with PTC Technical Support to be associated with the above RFC.
1 REPLY 1
AlanLew
(To:kschaefer-2)
