Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
We usually need make updates to a package that's used across all our models in all repositories.
As far as I understand it, the issue with the "Component Sharing" function is that it's slow to run using the Modeler client, you have to run it model by model and it almost makes the computer running Modeler unusable while it's processing.
The idea was to "queue" the package update in each model using the Modeler Manager without taking a personal computer hostage since this will run on the server side.
