When there is much quantity of a member and the subproject in Integrity, time considerably suffers from "Hide Empty Project" on a sand box view or a project view until filter processing is finished when I check it and carry out filter processing.
With the case which I confirmed here, in the case of the member of 300,000 cases, I assumed it 20min need for the processing time
I cannot carry out other work once on Integrity when filter processing starts until processing is finished.
If we choose other tabs on Integrity even if filter processing starts, can you not change specifications to cancel filter processing?
