[IM] "deferred relationship" between items possible?
JensN.
Hi @all,
today some users came to me and asked me if following would be possible:
We have amongst others two itemtypes in our changemanagement: lib-request and package-request. The lib-request has a relationship-field, which can hold some of the package-requests. The idea was that user a could place a package-request into the relationship-field of the lib-request, but this should be some kind of deferred relationship, and user B has to confirm (or negotiate) this relationship. Is this possible (without a third request)?
Thanks, Jens
1 ACCEPTED SOLUTION
mrump
(To:JensN.)
Hi Jens,
What about 2 relationship fields in the lib-request (like "proposed Relation" and "accepted Relation") and a kind of "staging/review" workflow?
Only one of the Fields (proposed Relation) is editable by the users, the other one is read only (except for your scripting accound)
Write a trigger script that copies the Relatiionship from one field to the other, in case the triggers run conditions are met (e.g. a State change to "confirmed")?
HTH Matthias
mrump
(To:JensN.)
Hi Jens,
HTH Matthias
JensN.
(To:mrump)
Hi Matthias,
thanks for your hint, this looks promising.
kind regards, Jens
