Implement connectorProperty
Implement connectorProperty and the ability to show the connector instance of the associated association block on the IBD.
In any case, there currently isn't an easy way to navigate from the connector to the typing association. Moreover, when the connector view options are set to display the connector's type it displays the association name, but when the association is described by an association block then the connector type should be the name of the association block.
2 Comments
PatrickOllerton
Status changed to: Under Consideration
We have this in our system as ART12-23377014 and are considering for the Modeler 9.3 release.
regards,
Patrick
olivierlp
Community Manager
Status changed to: Archived
