Import section/indention through/from EXCEL into Integrity/Windchill RV+S
Import sections through EXCEL into Integrity
Is it not possible to import into Integrity the "Section" column/field -> indention?
If not, is it possible to implement this feature in the excel add-in?
1 Comment
skamaraj
Hi @pbartha
To handle this situation, I use to import the items along with sections and any pick values via CSV Import tool and then will handle excel synchronization along with long text attribute content. Yes, this should be must have feature.
Also I remember PTC conveyed that when more items are imported without any hierarchy the IMAP order notation will be increased (I guess its O(N)^2). So I started this CSV import only for avoiding the relationship complexity.
Sathish
