While using Windchill RVN&S v12.3, we request the following improvements. so please review the patch or the next version.
1. When uploading files, only filename extensions allowed by the system can be uploaded.
2. When the mouse is over the uploaded file, the path is not displayed.
3. After logging out, it is impossible to search important information through the browser back function.
4. Limit the number of login attempts (restrict access if password is incorrectly entered more than 5 times)
5. Prevent two or more people from simultaneously logging into the same account.
6. Password change is applied periodically (more than once per semi-annual period)
7. When setting a password, apply rules (prohibition of consecutive number generation, mixing 8 digits or more of English / number / special characters)
8. The temporary password that was first created or reissued must be changed at the next access.
9. Prevents execution when uploading malicious files
10. Encryption (SSL) only for password transmission
