Hi Everyone,
I have a question regarding inserting picture captions in Integrity like in MS Word.
I am writing my system requirements in Integrity LCM and would like to export these requirements later in MS WORD. But i couldn't find the possibility to add Picture or Image captions in Integrity.
Could anyone has any clue about it?
Many thanks for your valuable suggestons and the time.
Best regards,
Rama
Unfortunately, PTC Integrity does not support creating Word-compatible captions within the Integrity rich text fields. You can add a line of text below or beside the embedded image within the rich text field that acts as the caption for that image, but when you export the Document to MS Word, that line of text will not be turned into a MS-Word figure caption; it will remain a line of text in the same field containing the image.
Does anyone have insights in the capabilities of the new WEB UI / new Rich Text Editor?
Is there a way to insert image captions with the new version?
Hello Rama Krishna Bollampalli,
Colin Doyle is correct. You can request this functionality by filing an enhancement request in our Ideas section.
Kael
