Hi guys,
I would like to ask if Integrity 2009 supports SOAP-based web services. I have service pack 6 installed. Do you have any documentation we can refer to?
JDCC,
Yes, we do support SOAP. You can find more information in our Web Services Reference document:
http://www.ptc.com/WCMS/files/143568/en/WebServicesReference_2009SP7.pdf
Hi Jeremy,
I don't have access to the location. I worked for a company and was given an MKS license but I do not know our customer details which are required to upgrade my access.
Could you please send me a softcopy via email?
Jeric
jdcc,
Please contact our support department at 1-800-477-6435 to get your account straightened out for you.
Do you happen to have a usage sample for python? I've tried several methods and cannot get past the follwing exception:
SOAPpy.Types.faultType: <Fault env:Client: Endpoint {http://webservice.mks.com/2009/Generic}Generic_2009Port does not contain operation meta data for: {http://webservice.mks.com/2009/Generic/}command>
(the exception is similar regardless of what WSDL and command I try to use)
David
Hello David,
Unfortunately, I do not have a usage sample for Python.
If you figure it out, or if someone else has an example, please post it here!
Kael
