Integrity 2010, how can I tell who is signed on to the system right now?
mmcfadden
I believe I found it: Server Diagnostics and then License usage. Thanks.
Hi Michael,
License usage will provide the license usage statistics for the Integrity Lifecycle Manager server application. To identify who's currently logged/signed into the system, while in the Administration client, you can expand Server Diagnostics and then use Client Connections, then select the run button.
Dragan
Hi Michael,
Dragan
You can also use CLI command si diag --diag=licenses which will give you the license statistics.
