Integrity ALM solution
satwal
2-Guest
We are using Integrity 10.4 for Change Control and Management but I now want to see what Requirements Managements features are available. However I cannot see any RM functionality. Do I need to install some additional modules?
On p203 of the Server Administration Guide for Integrity 10.4 (2013) it suggests downloading the ALM Solution template but I cannot see this anywhere on the site. Can anyone point me to where this might be available?
Thanks.
KaelLizak
(To:satwal)
Hello Sukhbir,
Please contact PTC Integrity Support to open a case to obtain the ALM solution.
IMT Solutions, once installed, are very difficult to remove, because they essentially create new workflows, document types, and the required fields, as well as triggers that inter-relate all of these objects appropriately. As a result, you will likely be asked about your usage to insure that you are installing the correct solution for your needs. Ideally, you have a development/test/sandbox server available that you can try it on, and wipe out with a database backup of the pre-IMT installation state, or a copy of production's database.
Kael
Kind Regards,
Kael Lizak
