Integrity CLI
johnm4
7-Bedrock
Integrity CLI
I am trying to get the Item ID of all types in Integrity, using CLI
The reason I want this is I would like to download all attachments that are associated with each Item Type
I can use the command  im extractattachments to download.
John
ascott
(To:johnm4)
Hi John,
im issues is probably the command you want. There are number of different variations, depending on what you want and what you find easier to craft.
For example,
im issues --fields=id --queryDefinition="(field[Type]=Requirement)"
Would give you an ID list of all issues of type "Requirement".
If you're doing more complex query filters to get your list, you can create a query in the Client GUI and then use:
im issues --fields=id --query="<name of your query>"
- So this would do the same but use the named query to find the issues.
I hope this helps!
-Andrew
