Integrity LM: Administration Configuration Reports
Intention
This document is intended to describe the current status of Integrity LM configuration reports and to collect related discussions and ideas.
Configuration Reports for W&D
  1. Integrity Docs
    • Custom developed offline solution creating static html pages about types and triggers for review and sharing
    • Is provided as a JAR file to be executed on client
  2. One alternative is "Type Fields in Excel"
    • Custom developed offline solution creating Excel Files instead of html files with similar information
    • Especially helpful when you are in a workshop and like to track requested changes directly in Excel for later implementation
  3. IMConfig
    • Custom developed Online solution for Admin reporting. For Type-Fields, the same java code is used here like in solution #2.
    • And, it offers many more reporting, not only "Type-Fields-Workflows". For example, it offers also reporting for User-Group-Dynamic-Group details.
    • Is provided as a single WAR file to be copied to the server
  4. Administration Reports
    • Custom developed Word Export showing Administration Configuration Details for Types, States, Fields etc.
  5. CLI
    • You can use the CLI to create config lists in CSV or XML format, and upload the same into any custom reporting tool.
    • I am using #3 instead, where possible.
  6. Relationship and Trace Listing
    • Custom Developed Excel List for all admin Relationships  and Traces. Created for Documentation and Validation purposes.
  7.  Trigger Overview
  • This report lists all Triggers with the name, and they are ordered by the type names on which the trigger fires.
  • Each box represents a trigger. Additional flags highlighting the type, the pre or post mode, if a script is linked etc.
Configuration Reports for Config Mgmt:
  1. for ACLs:
    • Standard Client Form providing ACL details in regards to given ACLs for users/groups and projects, subprojects
  2. In General
Next Steps
  • If you are aware of any other solution that I should list above, please post it here as comment.
  • If you are aware of any other related Idea or Discussion that I should reference, please post it also.
Related Discussions:
For W&D:
PTC Integrity Configuration Report
Re: Is there a possibility to give out all definition done in ILM "Workflow and Documents"
how to compare two Integrity configurations
Volker
Re: Integrity LM: Administration Configuration Reports
7. Trigger Overview  (added in Nov 2017)
Trigger Doc (created with Java)Trigger Doc (created with Java)
Where are these utilities located?
Hi Paul,
Thanks for asking. If you are a PTC employee you can get them from our internal reusable database. If you are an external (non PTC) employee, then drop me an email or a personal message with your email adress and I will contact you from where you can get them.
Thank you
How to generate this report?
Is there any way to kill a trigger and initiate it again? I am asking just in case there was a blockage and we killed the trigger , so how to trigger the trigger again??
about "How to generate this report?":
Please send me your contact and company details in a personal message.
about: "Is there any way to kill a trigger ....".
Please post this question into the Questions forum section, not under Tips.
Thank you.
