The proposal is to create a performant interface to Enterprise Architect (EA). It shall provide high quality import / export options to Integrity Modeler (IM) for model elements AND diagrams. In a further approach also synchronization shall be possible.
Such an interface would be needed i. e. for development projects in which the development partner uses EA, but the own company needs to have the results in PTC IM for further detailing (not only documentation).
Possible scenarios for the exchange with suppliers and development partners:
The actual universal interface XMI is far not sufficient because no elements can be imported and no diagrams can be transferred. Sync. is also not possible.
Furhter information on EA:
