Integrity Object Constraint
0 Kudos
Hi Team,
There should be some way we can find out Type of project that we are selecting is "Project" or "Library". I know there is a field called Project Classification that exactly do the same thing but this will work only after first time save means this will not work when our object in "Unspecified" State.
This may helps a lot during defining constraint and all on the basic of Library and project now in current configuration we have to select list of Project and Libraries on which we need to put Constraint and every time Admin need to update the list whenever a new Project or Library is added.
And may be current configuration helps if we need to put constraint on selected Project & Library , completely agree to that but apart from this there should be some way if user want to put Constraint on all Project & Library rather then selecting and maintaining in future in single shot.
Correct me if i am wrong.
Kapil
1 Comment
olivierlp
Community Manager
Status changed to: Archived
