After every synchronization between Integrity Modeler and Doors the synchronization tool terminates. Since the startup / restart of the synchronisation tool takes a while, time is lost in the case you whant to edit and synchronize multiple mappings in sequence.
The suggestion is to improve the synchronisation tool, so it do´s not close after each synchronisation task but returns to the start screen, ready for a further synchronisation.
Thanks.
