Is the process of migraion from RCS to database repository same for the production and staging server? If yes, how is it differnert for staging server?
spadaki
2-Guest
The migration of the production server from RCS to database repository is done. The staging server needs to be migrated. The available migration document http://support.ptc.com/WCMS/files/143564/en/MKSDatabaseRepositoryMigrator_2009SP7.pdf was referred for the process.
Can the same document be referred for the migration of the staging server as well?
Sujith
1 ACCEPTED SOLUTION
KaelLizak
(To:spadaki)
Hello Sujith Dattatreya Padaki,
Since staging is a Workflows and Documents process (source code doesn't get staged), migrating staging servers from RCS to a database backend should work the same on as many staging servers as you have.  You should confirm that you even have source repositories on your staging server--some organization's admins use them for storing configurations of machines in their computing environment, but most organizations only store source code on their production server.
Kael
Kind Regards,
Kael Lizak
KaelLizak
(To:spadaki)
Kael
Kind Regards,
Kael Lizak
KaelLizak
(To:KaelLizak)
Hello Sujith Dattatreya Padaki‌,
Did the last post get you going again?  If so, could you mark that post as resolving your issue by clicking on the Correct Answer button?  If not, could you let us know what challenges you are still facing?
Kael
Kind Regards,
Kael Lizak
