Is there a way to add comment while clearing the suspect? We want to record why the trace relationship has been cleared
sbakki
Hello Sudhakar,
unfortunately, the clear suspect form has not comment field.
What I usually suggest to my clients is to use the "Additional Comments" field instead.
This is a standard ALM field and can be added to the Content item if needed.
As this functionality is often requested by clients, this would also be a great Idea for this portal here.
Perhaps you can add one?
Volker
kjain-2
(To:sbakki)
Hi Sudhakar,
No you can't add comments during suspect clear. You can add an field to capture comments in your type.
Kapil
