I can use "Create Related Item" button to create a Release Item from a Defect Item
Problem is that logically it does not make sense to be able to do.
I expect the Release Item to exist before testing is done. Not the other way around.
Please suggest a way or add a feature to remove/gray out the "Create related item" functionality on the Defect Item on the Relationship Tab from the following Sections
"Customer Release"
"Known Issue in"
Please find attachment for the same.
