Computer 1 Location 1 : I create a subproject and share it. Visual Studio/File/Import Solution/ will show the share in the list.
Computer 2 Location 2 : Visual Studio/File/Import Solution/ doesn't show the Share in the list.
Any idea why ? Thank you
a+, 😃
-=Clement=-
Configuration :
MKS Integrity Client 2009 Build: 4.10.0.9665
Service Pack: 007-01 Hotfixes: C041000007-05, C041000007-015
Visual Studio 2008
I had the same problem the other day, but with help from PTC support found a solution, so I'm gonna post it here for reference for others:
The key point seems to be the handling of change packages. When you shared the solution (via File -> Source Control -> Share Solution), you must submit the corresponding change package. This *has* to be done from Visual Studio, *not* from the MKS Client itself! If done there, it seems to submit additional sharing information, which is required for other clients to find the share.
If you already submitted the CP via the MKS Gui, you can just reopen it, open the solution in Visual Studio, and submit the CP again from there.
Cheers,
Florian
Hello Clement,
Interesting! Please contact Integrity Support to have them investigate this.
Kael
Cheers,
Florian
Hello Florian,
Thank you for your anwer ! Some test show that this seems to be the right workaround.
@Michael : I have no ability to contact Integrity Support myself (I asked the internal MKS support team but they didn't know how to fix he issue)
a+, 😃
-=Clement=-
Configuration :
Visual Studio 2008
