MKS Integrity plugin for Eclipse
vk-4
We are using MKS Integrity 10.5 as our version control system.
It has Eclipse 3.4 plugin in the following location: c:\Program Files (x86)\Integrity\IntegrityClient10\integrations\IBM\eclipse_3.4\
Now we are planning to use Eclipse 4.5.1 software version.
So I would like to check can we use eclipse_3.4 plugin itself to work with Eclipse 4.5.1 software?
Please confirm are there any side effects because of this?
1 ACCEPTED SOLUTION
KaelLizak
(To:vk-4)
Hello vasavi k‌,
I'm not sure what would happen if you used the eclipse_3.4 plugin with Eclipse 4.5.1, but I suspect you wouldn't be happy with the result.  Integrity Lifecycle Manager 10.5 has support up to Eclipse 4.3.x, so you could try using that corresponding plugin.  The most recent supported release of Eclipse supported by Integrity is 4.4.x, which is supported by Integrity 10.6 or later.
In general, this information is pointed to in CS124646:  List of supported integrations for IntegrityThis document covers Integrity 10.0 to 10.8.
I hope that helps.
Kael
Kind Regards,
Kael Lizak
KaelLizak
(To:vk-4)
Hello vasavi k‌,
I hope that helps.
Kael
Kind Regards,
Kael Lizak
vk-4
(To:KaelLizak)
Hi Kael,
Thanks for the response.
Could you please let me know how to get the eclipse plugin? and how to install it.
KaelLizak
(To:vk-4)
Hello vasavi k‌,
This is outlined in CS120640:  Where to Download Integrity Products, Features, Hotfixes, Upgrades, and Documentation.
Kael
Kind Regards,
Kael Lizak
