Hi
im viewsegment -g --filterrule=((relationship["Summary"] forwards using ["Field1"] contains "TestVar") and ((field["ID"] = 12345) or (field["ID"] = 32432)))
How to get the advanced filter work from im commands , the above command shows this error
"MKS124814: Cannot show view information: MKS978530: This command accepts a selection of exactly one item id."
Is it not possible to get the Advanced Filter which works from gui , in im commands ?
Solved myself missing "
im viewsegment -g --filterrule=" ((relationship["Summary"] forwards using ["Field1"] contains "TestVar") and ((field["ID"] = 12345) or (field["ID"] = 32432))) "
