Make it easy to show suspect nodes
Right now, it's not so easy to filter on suspect nodes in the document view.
You have to select the filter on Trace Status, then select all values that contain the word "suspect", add them to the list and click ok.
Then means I either have to type the word suspect in the column filter or manually click on all the needed trace status values.
Especially for new users, this is hard to explain.
In my eyes, there are too many clicks/interactions needed for such a common task.
I'd wish for a more user-friendly support here OOTB.
To workaround this, I created a logical "suspect" attribute with is set by a trigger, so at least I don't have to care about th 27 trace status values.
I know I can also use Viewsets Perspectives or "Recent Filters", but for those I have to create the filter at least once. For new users, this is difficult to remember, or get it right the first time.
I suggest having besides (or in) the "where" filter a value "All Suspects" immediately filtering on all suspect trace states in the document view.
2 Comments
mrump
I would love to see that.
olivierlp
Community Manager
Status changed to: Archived
