Since 10.9 for me (I jumped from 10.4), the administration GUI asks me if I want to discard changes every time I cancel an edit even if I changed nothing.
It used to be smart and not do that. Note that the default is No and there's no hotkey, so you're forced to click on Yes.
If you're an administrator and you spend most of your time tweaking objects, chances are you always use the edit mode because there's no point in viewing a configuration and then deciding to edit it. You might as well jump into edit just in case and cancel if you change nothing.
This is a typical scenario now, when checking an item presentation template and making zero changes: edit item > open presentation template > cancel out of presentation > cancel out of item edit.
In this scenario, I am prompted twice even though there is zero unsaved information. This is extremely annoying and time consuming (you still spend a second making a mental check).
Again, in previous versions I was prompted only if I had made changes and it made sense. I need this back as soon as possible. I reported this as a defect a few months ago but I have no feedback so I think it needs more visibility.
