Currently it is not possible to edit the format of multiple items at once.
The possibility to multi-edit the formatting of rich text fields in a document in Integrity (ie make these items bold, italic, change the font size, etc.) would make things a lot easier and save a lot of time.
This topic was already reported to R&D as enhancement RFC 102875 (see Case CS154986), but the RFC process was moved and the issue was left in state 'analyzed'.
The functionality described in the title would really help us and save a lot of time.
