A native support for a glossary would be great, where you can enter terms and definitions and then have an easy way to manually or automatically refer to the terms.
Could be as easy as an <abbr> tag, only showing the definition in a tooltip or more sophisticated, like a link opening the respective glossary item.
Another use case for glossary would be to be able to add it to a document as a chapter.
