Need suggestion on Command
ptc-6083798
Hi
I am just trying to add constraint through following command,
im edittype --Port=7000 --addFieldRelationship=constraintrule="((field["Regulated State/Province/City"] <>"California") and (field["Regulated State/Province/City"] != ""))":"Local District"="Houston-Galveston-Brazoria,Dallas- Fort Worth,Beaumont,Port Author",description="desc" typename
but this is not working as expected. is this command correct?
because though i am specifying typename it is asking me "This command accept selection of exactly one type"
if I am wrong please help me in getting correct command.
Rahul,
I noticed something. Try this:
im edittype --Port=7000 --addFieldRelationship=constraintrule="((field["Regulated State/Province/City"] <>"California") and (field["Regulated State/Province/City"] != ""))":"Local District"="Houston-Galveston-Brazoria,Dallas- Fort Worth,Beaumont,Port Author" --description="desc" Function
The problem is most likely in the description parameter.
It is probably due to the use of double-quotes all throughout the command. I would suggest wrapping the entire constraint rule value in double quotes(") like you have and then inside that, for the field names and values, use single quotes instead (').
Joe,
I've ran in to that issue before, however, what resolved it was single quote (') around the entire parameter and double quote (") around the field names and values.
JoeBartlett
20-Turquoise
(To:DanR.)
It doesn't really matter which way you do it, as long as the command can tell the difference between the whole command string and the individually-quoted values within it.
