New Branch ID from Branch Triggers
"Item is branched" triggers, which use the imBranchArgsBean, should have access to the ID of the newly created branch.
Possibly related: Branching & Create from Template actions detectable by event triggers
3 Comments
lreveillere
1-Newbie
Hello Cody,
I have just crossed that problem because I wanted a relationship field linking the branched item from the original one.
It is possible to get something like that by simply calling a post-trigger in branched (there you can get with the branchResultBean the IDs of the original and branched one)
if (branchResultBean != null)
        branchingIssueID    = branchResultBean.getBranchingIssue();
        resultingIssueID      = branchResultBean.getResultingIssue();
Then if you need to do something with one of them you can directly make a JAVA call and modify those items (example below)
var apiSession = eb.createAPISessionBean();
var commandRunner = apiSession.createAPICommandRunnerBean();
resetCommandRunner(commandRunner);
commandRunner.setCommand("im","editissue");
commandRunner.addOption("field", "MY_RELATIONSHIP_FIELD_NAME" + "=" + branchingIssueID);
commandRunner.addSelectionElement(resultingIssueID);
try{
   var result = commandRunner.execute();
   Packages.com.mks.api.util.ResponseUtil.printResponse(result, 1, java.lang.System.out,true);
So this does but it can have some performances issues if the document is really big and the server is slow.
I hope it helped.
Best Regards
Mr. Lionel Réveillère
PTC ALM Consultant
dpeter
Hi Cody Carey  ,
Does the solution provided by Lionel help?
Can you confirm that you are interested to get the value of resultingIssueID from imBranchArgsBean?
KartikOak
Status changed to: Archived
Archived in the absence of the requested clarification.
Kartik
