New general read-only access role for Workflow & Documents
Today role everyone by default has write permissions to any item he is allowed to access.
There is no role available btw. no direct ACL that allows to reduce Access onto read-only.
Existing Workarounds are:
Article - CS91600  (Ability to enable read-only document view in Integrity Lifecycle Manager)
Article - CS92871 (Ability to have read-only mode for Workflows and Documents Web Interface in Integrity Lifecycle Manager)
CS165820  (Configure edit or read only privileges to item backed projects for multiple groups in Integrity Lifecycle Manager for Workflows and Documents)
All are either not fitting to my question how to allow Read-Only access in the GUI for "Workflow and Documents" not only for Documents but for EVERY Item type used.
Thus I ask for such an GUI extension.
2 Comments
VolkerEckardt
Tag
Value
Status:
Reviewed by PTC Community Member
Main Category:
Integrity Lifecycle Manager Administration
Sub Category:
User and Group Management
Related Working Group:
Standard Functionality validated:
Default Groups
Standard Functionality available in Release 11.2:
Partially
Workaround exists:
Yes
Workaround Description:
Define Read Only Groups and assign them to all Types
see below
Workaround match:
100%
Other known solutions:
n/a
Related other Ideas:
none identified
Related Questions:
none identified
Related Tips:
none identified
Next review Milestone:
01/11/2018
Perform the following steps:
  1. Create a Domain group "ReadOnlyAccessGlobal"
  2. Create a Dynamic group "ReadOnlyAccessByProject"
  3. Add to every Item, Document and Node the following Editability rule
    User is not member of ReadOnlyAccessGlobal
    and User is not member of ReadOnlyAccessByProject
    (this Editability definition for each type can be done manually, or via CLI)
  4. If you now add a user into
    a) the ReadOnlyAccessGlobal
    or b) ReadOnlyAccessByProject
    then this user can not edit the items/doc/nodes - globally, or project specific - anymore. The global definition will cause the user to become immediately read only in all W&D projects.
olivierlp
Community Manager
Status changed to: Archived
