At the moment there is no sub-numbering in a text field. In a numbered list should be a sub-numbering like in Microsoft Word (1.1). If I press now <tab> in a numbered list the next row begins again with 1 and not with 1.1.
Actual:
1. "This is capitle 1"
<tab> 1. "This should be capitle 1.1"
<tab> 1. "This should capitle 1.1.1"
Expected behaviour:
1. "This is captile 1"
<tab> 1.1 "This is captile 1.1"
<tab> 1.1.1 "This is capitle 1.1.1"
