In one of our item types the state’s pick list value "ALM_Started" the order is not correct. Currently it is ALM_Prepared, ALM_Started, ALM_Implemented, however we would expect ALM_Started, ALM_Prepared, ALM_Implemented. The order of the states in the pick list is dependent of the position of the state. Can the position of the state "ALM_Prepared" be changed (move below ALM_Started) without impacting other State pick lists.
The pick list is not sorted alphabetically, it is arranged by order. The order never changes for the pick field depending on the current state of the item. We would prefer to sort the picklist order displayed depending up on the current state of the Item.
