Has anyone used the Integrity SCM capability to version control their Sparx EA project/models?
If so, how does this work and how do I connect EA to the Integrity repository?
Thanks!
Kris
It does exist and I got it working with the help of Cletus D'Souza,
Hello Kris,
Are you looking for an integration between Source Integrity and Sparx EA? To my knowledge, such a thing does not exist. CS84749: Support for item integration with Sparx Enterprise Architext in Integrity and CS85887: How to integrate Integrity Configuration Management functionality with Sparx Enterprise Architect. Having said that, apparently you should discuss this with an Account Manager and/or Global Services, as they may be able to assist.
Kael
Hello Kris and Kael,
I need the solution you got from Cletus, how can I get it?
Hello Laurent Lawton,
If it's an FDO (Field Deployed Object), you'll have to go through your account manager. There is no "core" integration with Sparx Enterprise Architect.
Kael
