Perspective used to be displayed on the Word template
Initial situation: Open a document and apply a perspective. Export document to Word.
System response:  When you export to Word, the perspective you are using is not displayed. And there is no possibility to map these information over gateway config.
Expected situation: It should be possible for the perspective used to be displayed on the Word template.
1 Comment
Dr_Bensch
3-Visitor
The following should be considered during implementation:
In order for the Word document to be reproducible, the perspective must not be manipulable. Therefore, it must also be possible to:
- When exporting Word, the perspective to be exported is selected (so that the document cannot be filtered additionally)
- Only a certain role is allowed to change perspectives that are stored on documents
