THIS issue below should be fixed with an update of the Eclipse Plugin to support Eclipse higher than 4.4
Eclipse Intergrity plugin not showing correctly
We are planning on supporting higher versions of Eclipse soon.
Newer versions of eclipse are supported from Integrity Lifecycle Manager 11.2 and onwards.
