In PTC Integrity we do not have an inbuilt functionality to validate date fields.
There should be possibilities to set rules to validate date fields:
For e.g.:
1) Comparison of 2 date fields -> Compare and decide if an entered date value is less than or greater than another already entered date field.
2) Compare a target date value and see if it is greater than created date of an item
3) Compare an issue injection date and validate if it is not a date in the future.
There should be configurations to set logics behind every date field. This would be very much beneficial.
