The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Project Filter to be configurable by tab. Should not be identical in each tab for RV&S
0 Kudos
The project filter should be able to be different for each tab open in RV&S. Example - you have a query open for all sub level documents. You set the project filter to the projects you are working on. Then in tab 2 you have a query open for all Layer 2 documents. You are working on the layer 2 documents in a different set of projects. You should be able to configure the project filter so it doesn't change the project filter on the first tab.
1 Comment
KartikOak
Status changed to: Alternate Solution
             As you may be aware a major chunk of enhancements to Windchill RV&S are in the Refreshed Web UI. See below how this would work in the Web starting with the Windchill RV&S 13.1 release  - the user can set different Project Filters for each Query they work with.
Kartik
