Propagate traces between versioned documents
Current Situation:
When creating a branch, a Label can be specified. This is not possible when traces are created.
This results in the fact that all traces are copied from the live document.
IDEA:
When creating propagate traces, the source shall be the traces on base of a label, i. e. the document and not the live document shall be used.
4 Comments
GauravPhadtare
GauravPhadtare
Why do you want to have traces propagated from the historical document? What is the use-case? As you know the branched document might have so evolved that the trace propagation from the historical document may not be helpful.
GauravPhadtare
Status changed to: Clarification Needed
olivierlp
Community Manager
Status changed to: Archived
Hello @liebeaex
We are following up on @GauravPhadtare 's request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
