2 ideas in one.
1. would like the ability to propagate internal traces within a segment as certain customers often trace from nodes to nodes within a segment
2. propagate traces wizard requires propagation to 1 target at a time. For example, if i have a requirement that is traced to 5 test cases and those 5 test cases are in different documents i must propagate 5 times instead being able to multi-select all 5 targets and propagate in a single gesture.
