According to https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS242136 it is not possible to rename a repository and there is only a workaround available (copy to new datastore).
It would be good if Modeler provides such functionality to make administration of "organization"-repositories easier, e.g. when department is renamed.
