I am trying to create an item that can be used as a "Related Item" in the Test Result Editor. I use the chain link to create a related item. When I try to save it I get the error "Could not save item: Editing FVA: Relationship field References is empty". Could anyone explain this or point me to documentation that explains it? I haven't been able to find anything anywhere on this error.
Nolin
To follow up: The solution to this issue was captured in CS198226.
Thanks for your patience on this one, Nolin.
Kael
Hi Nollin,
Could you contact PTC Integrity Support to have them investigate this with you?
Kael
Kael
