Remove 3000 limit for the "Show Items Containing" field
The show items containing field is disabled where there are more than 3,000 entries.
Relax this restriction to a higher number or move it to the admin settings so the value can be increased for particular installations.
The where filter is not of much use because the field wanted to be searched doesn't contain spaces and wildcards are not allowed at the start of the search term.
If I wanted to search for PR_8 then I would also need to include the full prefix
3 Comments
Neeraj_Jain
Regular Member
Do you have any update on implementation Plan of this idea by PTC?
wbgouveia
Visitor
Remove 3000 limit for the "Show Items Containing" field sounds like a good Idea, if we have the "Integrity" growning up into our company (and we have 3000+ items to search) so why block "show items containing"? May be performance? if this is the problem I think this item needs enhacements.
Wellington
Siddharth
Granite
