The following report field computation flags an item with a 1 if its State on a specific date/time was 10 (i.e. Closed):
HistoricFieldValue(State,timestamp("Apr 1, 2013 11:59:59 PM")) == 14 ? 1 : 0.
However, I’d like to flag with a 1 if the historical State was 10 (Closed) or 41 (Canceled). I've made several attempts to no avail. Can you assist please?
Hi Anita,
I don't have much experience with the HistoricFieldValue() itself, but I do enjoy computed fields .
From how I see it, there are 2 ways to get the functionality you mentioned..
The more straightforward way is to use parentheses to group the OR:
((HistoricFieldValue(State,timestamp("Apr 1, 2013 11:59:59 PM")) == 10) or (HistoricFieldValue(State,timestamp("Apr 1, 2013 11:59:59 PM")) == 41)) ? 1: 0
An alternate way is to use nested ? operators:
(HistoricFieldValue(State,timestamp("Apr 1, 2013 11:59:59 PM")) == 10) ? 1 : ((HistoricFieldValue(State,timestamp("Apr 1, 2013 11:59:59 PM")) == 41) ? 1 : 0 )
Hope that helps,
Matt
Hi Anita,
Hope that helps,
Matt
thanks, Matt. I really appreciate your help.
