In requirement management, if I unfortunately deleted some item then if I try to restore it back, then its very difficult. I need to view the document history, then look for the attribute content then have to add the item content manually. Moreover this leads to adding of new Item ID and cannot restore back the existing deleted Item.
It will be nice if PTC provides below features,
1. Adding back the dropped item as similar to "Add from Archive" in Source (this is more flexible)
2. Restoring an item on particular point of time,
3. Restoring back the entire document (may be based on access privilege, like only DocAdmin shall perform this)
This shall save much time, also shall eliminate manual effort and provide more accuracy results.
Its truly as similar to "Add from Archive" and "Restore projects" commands available in Source Integrity.
Advantage:
This will eliminate hanging of deleted reference Items
Provide more accurate "undo"/"restore" data
Helps to avoid manual editing that saves lot of time.
Thanks and Regards,
Sathish
