Hi @all,
is it possible to set a complete Branch (DevPath) in source to readonly, and the parent is still writable?
Thanks, Jens
Hi Jens,
that's easy.
You just need to create a specific ACL for the Dev Path and deny the
permissions for the everyone groups
HTH Matthias
Note: Keep in mind that you ensure the ACL for the Dev Path is not inherited from the mainline.
Hi Jens,
that's easy.
HTH Matthias
Hi Matthias,
thanks again
kind regards, Jens
