as configuration path works better within Integrity and sandboxes can be created with configuration path, but only through command line... =(because the GUI creates the sandboxes with flat path syntax).
Did anyone come up maybe with a custom command of creating sandbox with configuration path of the project?
This would help a lot for our regular Integrity users who prefers to work within the GUI.
Thanks beforehand, bye, Péter
